Re: [Nagios-devel] Event handler for every incoming passive check possible?
------=_NextPart_000_00BF_01C39745.0060FE40
Content-Type: text/plain;
charset="iso-8859-1"
Passive checks are recorded in the log file, perhaps you could parse =
that if the event handler doesn't do what you need?
Jim
----- Original Message -----=20
To: [email protected]=20
Sent: Monday, October 20, 2003 5:28 PM
Subject: [Nagios-devel] Event handler for every incoming passive check =
possible?
Hi, i want to create an rrdtool program for incoming passive checks.
This would be pretty easy if nagios supported event handles for every =
incoming passive check, instead of only on changing states. This way I =
could redirect the output to a program that parses the numbers and =
triggers an RRD update.
Does anyone know if this is possible?
Thx
Content-Type: text/html;
Passive checks are recorded in the log =
file,=20
perhaps you could parse that if the event handler doesn't do what you=20
need?
Jim
ForMatPrO=20
rceforge.net=20
Sent: Monday, October 20, 2003 =
5:28=20
PM
Subject: [Nagios-devel] Event =
handler for=20
Hi, i want to create an rrdtool program for incoming passive=20
checks.This would be pretty easy if nagios supported event =
handles for=20
every incoming passive check, instead of only on changing states. This =
way I=20
triggers an=20
RRD update.Does anyone know if this is possible?Thx=20
------=_NextPart_000_00BF_01C39745.0060FE40--
