Re: [Nagios-devel] Possible discrepancy in Documentation and Functionality
Zac wrote:
> Hello,
> I have been running nagios 1.x for a long time now and am very excited to
> start using v2. I have setup a development system and am re-organizing my
> config with some of the new features. I have run into an issue that,
> according to the way I am interpreting the documentation should work.
> What I am trying to do, is remove the hostgroup definitions in favor of
> putting the hostgroup line in the host definition template. I am hoping to
> remove the long lists of hosts on the members line. In the documentation it
> states that it can be "used as an alternative to (or in addition to) the *
> hostgroups* directive in host
> definitions."
> but this doesn't seem to be the case. If I do not make a hostgroup
> definition, and only use the hostgroup line in the host definition, I get
> the error that the hostgroup doesn't exist. If I create the hostgroup and
> put 1 host in the members line, everything works, but it breaks my
> templates, or puts a duplicate host or service in the group and makes my
> config files more confusing. If I create a hostgroup with no members line,
> it errors out as well.
The hostgroup still needs to be created. There doesn't have to be a
"members" line, but there has to be hosts in the hostgroup. You can thus
create a config such as this
define hostgroup{
hostgroup_name hostgrp
alias Alias for hostgrp
define host {
use the_template_that_includes_everything
host_name the_host
hostgroups hostgrp
> My question is, is it planned that I can use the hostgroup directive in the
> host definition as a complete alternative to the hostgroup definition?
No. It's planned to replace/extend the "members" directive in the
hostgroup object definition. Hostgroups aren't created on the spot.
> I
> understand we need to define the alias for the host group, and I would be
> fine with creating the hostgroup definition and only populating the name and
> alias, but I really want to avoid duplication or messy members lines.
Then this is what you should do. I know for a fact that it works, so if
you can't make it so, send me your configuration and I'll test it myself.
OP5 AB www.op5.se
