Re: [Nagios-devel] Nagios 3.0 RC2: Segmentation faults after
Christian Schneemann wrote:
> On Thursday February 14 2008 03:34:17 pm Hendrik Bäcker wrote:
>> Christian Schneemann schrieb:
>>> On Thursday February 14 2008 03:05:54 pm Hendrik Bäcker wrote:
>>>> Well - what happend to your path "/var/spool/nagios" ?
>>> Nothing... I'm seeing files appearing, and then it segfaults after a few
>>> files..
>> Ok... digging the nose.
>> Please show us:
>> * su - nagios (or whatever your nagios user is named)
>> * ls -la of your /var/spool/nagios/
[snip]
>> Hendrik
> And here some more background info:
> nagios is compiled with --enable-embedded-perl and embedded perl is
> deactivated in thte nagios.cfg.
> If I enable it in the nagios.cfg nagios runs fine without segfaulting. Do you
> have any ideas?
Strange. What if you recompile the Nagios daemon without embedded perl?
Does it segfault then? I would think enabled embedded Perl would
cause more problems than not...
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
