Re: [Nagios-devel] Recovery not getting sent during downtime?
[email protected] wrote:
> Hi folks,
> I'm currently using Nagios 2.0b3 (never change a running system ;)) and
> ran
> into the following problem:
> Service went critical
> SMS and emails got dispatched
> found problem, decided to reboot the machine to fix it
> scheduled downtime for host
> rebooted host
> everything went ok again
> no SMS/email got dispatched to state the service recovered though!
> I'm unsure if this problem was already fixed, I didn't find any real
> evidence in google or the changelogs. Though fixes in the
> recovery logics and notifcation system itself were documented,
> they weren't too detailed though.
> Question: is this a bug or feature? If it is a bug, has it been fixed in
> a newer release which I can update to?
[snip]
This sounds like a bug. I don't recall the exact specifics of the
notifications bug fixes in the 2.x branch, but I think at least one
dealt with scheduled downtime. You should upgrade to 2.5 to catch up on
other bug fixes as well. Hope that helps.
Ethan Galstad,
Nagios Developer
Email: [email protected]
