--------------040509010000050403070809
Content-Type: text/plain; charset=ISO-8859-15
On 05/24/2012 11:30 AM, Andreas Ericsson wrote:
> On 05/18/2012 12:52 AM, Jochen Bern wrote:
>> On 05/11/2012 09:34 PM, Jochen Bern wrote:
>>> Everyone,
>>> I played with the "-c" and "-s" Parameters of a 3.2.3's nagiostats to=
day
>>> and noticed the odd behavior shown below. [...]
>> Any chance that the -s option might be reappropriated to read the
>> current status.dat files via read_status_file(), rather than a format
>> lost in the sands of time ... ?
>=20
> Sounds like you've already done a large part of the analysis, so it mig=
ht
> be good if you did the patch as well.
Very well. The attached patch is for 3.2.3, which is what I have at hand
right now both source- and real-world-example-data-wise. Does it happen
to apply cleanly to 3.4.1 ... ?
Kind regards,
J. Bern
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D Running new tests against unpatched execut=
able =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
[root@nagios nagios-3.2.3+all]# make test-perl
705nagiostats.t ................. 9/10
# Failed test 'Explicit generated status file contains host(s)'
# at 705nagiostats.t line 37.
# '0
# matches '/^0$/'
# Looks like you failed 1 test of 10.
Result: FAIL
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D Compiling patched source and re-running te=
sts =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
[root@nagios nagios-3.2.3+all]# make all
cd ./base && make
make[1]: Entering directory `/root/nagios-3.2.3+all/base'
gcc -g -O2 -DHAVE_CONFIG_H -DNSCORE -o nagiostats nagiostats.c -lm
make[1]: Leaving directory `/root/nagios-3.2.3+all/base'
705nagiostats.t ................. ok
Result: PASS
make[1]: Leaving directory `/root/nagios-3.2.3+all/t'
--=20
7
Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver Mic=
hel
name="nagios-3.2.3-nagiostats-s-option-patch.txt"
filename="nagios-3.2.3-nagiostats-s-option-patch.txt"
diff -Naur nagios-3.2.3/base/nagiostats.c nagios-3.2.3+all/base/nagiostats.c
--- nagios-3.2.3/base/nagiostats.c 2010-10-04 05:56:55.000000000 +0200
+++ nagios-3.2.3+all/base/nagiostats.c 2012-06-20 23:26:52.000000000 +0200
@@ -401,7 +401,14 @@
/* read pre-processed stats file */
if(nagiostats_file){
- result=read_nagiostats_file();
+ /* 20-Jun-2012 The format that read_nagiostats_file() tries to parse seems to have
+ been dropped entirely some time ago. Replace it with read_status_file() so that
+ the --statusfile option serves *some* purpose at least */
+ /* result=read_nagiostats_file(); */
+ if(status_file)
+ free(status_file);
+ status_file=strdup(nagiostats_file);
+ result=read_status_file();
if(result==ERROR && mrtg_mode==FALSE){
printf("Error reading stats file '%s': %s\n",nagiostats_file,strerror(errno));
return ERROR;
diff -Naur nagios-3.2.3/t/705nagiostats.t nagios-3.2.3+all/t/705nagiostats.t
--- nagios-3.2.3/t/705nagiostats.t 2009-05-15 01:52:42.000000000 +0200
+++ nagios-3.2.3+all/t/705nagiostats.t 2012-06-20 23:18:51.000000000 +0200
@@ -12,10 +12,11 @@
my $topdir = "$Bin/..";
my $nagiostats = "$topdir/base/nagiostats";
my $etc = "$Bin/etc";
+my $var = "$Bin/var";
-plan tests => 5;
+plan tests => 10;
-my $output = `$nagiostats -c "$etc/nagios-does-not-exit.cfg"`;
+my $output = `$nagiostats -c "$etc/nagios-does-not-exist.cfg"`;
isnt( $?, 0, "Bad return code with no config file" );
like( $output, "/Error processing config file/", "No config file" );
@@ -23,6 +24,14 @@
isnt( $?, 0, "Bad return code with no status file" )
...[email truncated]...
