Re: [Nagios-devel] Variables encoded twice
> The submitted parameters are processed by sanitize_cgi_input() at the
> start of the CGI. There is no added security if we process them again at
> this point.
> Example: If you have a host with the name SDSL:Customer you can call
> avail.cgi for the first time with no problems. But if you change the
> timeperiod and resubmit, the hostname is converted to SDSL%3ACustomer
> and you get an error.
Thanks for your example. Yes, you are right, this is not as it should work. It's a bug. The wrong conversion also happens for hosts with a backslash in its name.
I agree, there is no additional security since the browser encodes special characters.
But since we are printing out data from the user (host_name) directly to the browser, we should ensure that characters with a special HTML meaning are encoded. By default, such characters ( " ') are not allowed (see illegal_object_name_chars in nagios.cfg).
Think of a user who changed illegal_object_name_chars so that the apostroph ' is an allowed character in a host's name:
define host {
use linux-server
host_name John's server
alias Test 5
address 127.0.0.1
The output of avail.cgi without encoding is
value is set to "John", and "s server'" is incorrect HTML and ignored by my browser. Pressing the Update button now searches for a host named John.
So try
printf("\n",html_encode(host_name,FALSE));
in avail.c (I've only tried the host part but I assume it should apply to all your patched lines) and you'll see it works correctly then for both hosts "SDSL:Customer" and "John's Server".
Can you please verify this and resubmit the patch if you agree?
Have a nice weekend!
Regards
Bernd
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
