Reinstall check_nt plugin
cwireless
Post by cwireless »
We have this configuration:
Red Hat Enterprise Linux Server release 5.3; 32 bit; VMWare Image of NagiosXI; No special configurations.Using Internet Explorer.
We did not take a backup for plugin check_nt and we delete the command and the plugin; so we want to reinstall it.
How can we download and reinstall this plugin. We tried to scp the plugin from our core, but it keeps displaying
[nagios@nagioscwp libexec]$ ./check_nt
-bash: ./check_nt: cannot execute binary file
rdedon
Re: Reinstall check_nt plugin
Post by rdedon »
From the Nagios XI web interface please go to Admin, on the bottom left you will want Manage Plugins.
Please see attatched image:
Also, we STRONGLY suggest using Firefox as Internet Explorer is not supported and can be very problematic ;-)
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
cwireless
Post by cwireless »
Ok Thanks a lot,
and how to restore the command line for the plug in, what value was there?
example: check_nt!PROCSTATE!-d SHOWALL -l $ARG1$
rdedon
Post by rdedon »
the default is:
$USER1$/check_nt -H $HOSTADDRESS$ -p $USER7$ -s $USER8$ -v $ARG1$ $ARG2$
Rene deDon
Technical Team
___
