Re: [Nagios-devel] Possible discrepancy in Documentation and Functionality of Nagios v2.0b6
------=_Part_1923_11591613.1135866755033
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
As I understand it, the rules are to always over write the template, so if
you want the host to appear in cf-appservers as well as in cf-servers, then
you will need to put both in the hostgroup directive in the host
definition.
-Zac
On 12/29/05, Morten Werner Olsen wrote:
> On Thu, Dec 29, 2005 at 09:00:25AM +0100, Morten Werner Olsen wrote:
> > On Wed, Dec 28, 2005 at 06:54:31PM +0100, Andreas Ericsson wrote:
> > > The hostgroup still needs to be created. There doesn't have to be a
> > > "members" line, but there has to be hosts in the hostgroup. You can
> thus
> > > create a config such as this
> > > define hostgroup{
> > > hostgroup_name hostgrp
> > > alias Alias for hostgrp
> > > define host {
> > > use the_template_that_includes_everything
> > > host_name the_host
> > > hostgroups hostgrp
> > This works for me now after upgrading to 2.0rc1 (I believe it didn't
> > in 2.0b4), and that is great! :) But this resulted in another problem
> > with defining the hostgroups in template-hosts only:
> > # cf template host (based on another global template)
> > define host {
> > use linux-host
> > name linux-host-cf
> > hostgroups cf-servers
> > contact_groups cf-core
> > register 0
> > # cf-servers - host group definition
> > define hostgroup {
> > hostgroup_name cf-servers
> > alias cf-servers
> > # cf-app1 - application server #1
> > define host {
> > use linux-host-cf
> > host_name cf-app1
> > alias cf-app1
> > hostgroups cf-appservers
> > address 10.0.0.21
> > [a lot of hosts]
> > # diffhost - last host based on linux-host-cf template
> > define host {
> > use linux-host-cf
> > host_name diffhost
> > alias diffhost
> > address 10.0.0.43
> > The wierd thing is that diffhost is the only host showing up
> > (webinterface) in the cf-servers hostgroup, and I also get warnings
> > during the configtest about the other hosts having no services
> > associated with them (I specify a ping-service to the cf-servers
> > hostgroup).
> Just noticed that diffhost is the only host not having a hostgroups
> definition, so I believe this is not so wierd afterall, but just the
> hostgroups definition from the template that is overridden for
> cf-app1? I would like to see this work out with adding hostgroups both
> in the templates and in the host definition, but it is probably
> breaking the basic rules for templating in Nagios?
> - Werner
> This SF.net email is sponsored by: Splunk Inc. Do you grep through log
> files
> for problems? Stop! Download the new AJAX search engine that makes
> searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
> http://ads.osdn.com/?ad_id=3D7637&alloc ... op=3Dclick
> Nagios-devel mailing list
> [email protected]
Content-Type: text/html; charset=ISO-8859-1
if you want the host to appear in cf-appservers as well as in
cf-servers, then you will need to put both in the hostgroup directive
in the host definition.
-ZacOn 12/29/05, Morten Werner Olsen <[email protected]> wrote:<blockquote class=3D"gmail_=
quote" style=
...[email truncated]...
