When I acknowledge a service I type in a comment.
Later down the track when the service state returns to normal the comment dissapears.
Is it possible to display a report of comments for a service (or host) or are they lost forever?
Nagios XI 2009R1.4B running on a VMware VM on an ESXi 4.1 host.
How can I see historic comments
- Box293
- Too Basu
tonyyarusso
Re: How can I see historic comments
There are two MySQL tables (in the 'nagios' database) that appear to retain it after the service returns to OK:
mysql> select * from nagios_acknowledgements\G
*************************** 1. row ***************************
acknowledgement_id: 1
instance_id: 1
entry_time: 2011-01-26 12:14:37
entry_time_usec: 684438
acknowledgement_type: 1
object_id: 140
state: 1
author_name: Nagios Administrator
comment_data: asd
is_sticky: 1
persistent_comment: 0
notify_contacts: 1
*************************** 2. row ***************************
acknowledgement_id: 2
instance_id: 1
entry_time: 2011-02-22 07:43:17
entry_time_usec: 301751
object_id: 165
state: 2
comment_data: Testing for Box293
is_sticky: 1
notify_contacts: 1
2 rows in set (0.00 sec)
mysql> select * from nagios_commenthistory where commenthistory_id=102\G
commenthistory_id: 102
instance_id: 1
entry_time_usec: 482647
comment_type: 2
entry_type: 4
object_id: 165
comment_time: 2011-02-22 07:43:17
internal_comment_id: 102
is_persistent: 0
comment_source: 0
expires: 0
expiration_time: 1969-12-31 18:00:00
deletion_time: 2011-02-22 07:45:52
deletion_time_usec: 222997
1 row in set (0.00 sec)
Hmm...I'm not sure about the purging process for comments, or how to change that. Here's what I know about comment and where they're stored. We don't have a front-end tool for accessing comment history.
DB:
- In MySQL there's the nagios.nagios_comments table which seems to store current active comments
- nagios.nagios_commenthistory which might have what you need. It seems to have non-persistant comments
FILE:
- comments (while in existence) are stored in the status.dat file, defined as "hostcomment" or "servicecomment."
DB:
FILE:
