[Nagios-devel] =?utf-8?B?TlJQRSAxLjggcHJvYmxlbTogb3V0cHV0IHJldHVybnMgIsO/wr4=?=
Wierd problem this. Unfortunately, beyond my skills to find a fix!
If I run nrpe on a SunOS 5.8 server with check_write_to_null defined as a
shell script that does this:
#!/usr/bin/ksh
print -u2 "$0"
The idea is a plugin that writes to stdout with nothing to stdin (I actually
get this problem if the #! program doesn't exist because perl is not
installed).=20
If I then run check_nrpe -H host -c check_write_to_null, I get "=C3=BF=C2=
=BE=C3=A7=C3=BF#".
If nrpe is run on a SunOS 5.6 server, I get "NRPE: Unable to read output" as
expected. I think the problem starts in my_system(), but I don't understand
why.
This is on NRPE 1.8.
Anyone got any ideas?
Ton
This private and confidential e-mail has been sent to you by Egg.
The Egg group of companies includes Egg Banking plc
(registered no. 2999842), Egg Financial Products Ltd (registered
no. 3319027) and Egg Investments Ltd (registered no. 3403963) which
carries out investment business on behalf of Egg and is regulated
by the Financial Services Authority. =20
Registered in England and Wales. Registered offices: 1 Waterhouse Square,
138-142 Holborn, London EC1N 2NA.
If you are not the intended recipient of this e-mail and have
received it in error, please notify the sender by replying with
'received in error' as the subject and then delete it from your
mailbox.
