using templates you can define a default alias - alias is only used if you
need it in notifications...
however host_names have to be unique and the address field can contain
more than one address - so they have to be entered
also 1.x is in a bug fix mode only
development/features are in 2.x
It might be simpler to write a pre-init script that parses the config and
writes out the address if needed from the hostname.
-sg
On Tue, 15 Feb 2005, sean finney wrote:
> hi nagios-devel,
> we have a feature request from a user that i think is pretty reasonable
> and not too big an effort to accomplish. basically, nagios requires
> that all host objects have a host_name, address, and alias attribute.
> the user requested that as a default, if only the host_name is provided
> that it be used to derive the other two attributes.
> btw, this is for the 1.x cvs branch.
> thoughts? comments?
> sean finney
> (debian nagios package maintainer)
> ps - i would appreciate it if you would maintain the CC field so that
> further correspondance is kept with the bug record.
> ----- Forwarded message from txemi -----
> From: txemi
> To: Debian Bug Tracking System
> Subject: [Pkg-nagios-devel] Bug#294983: wishlist: not require alias and host_name in hosts.cfg
> Date: Sat, 12 Feb 2005 21:24:29 +0100
> Package: nagios
> Severity: wishlist
> Most boring thing of setting up nagios is writting big configuration files.
> But some little changes could in my opinion short and increase readability of this files.
> In my hosts.cfg I have a lot of sections like this:
> define host{
> use my-generic-host
> host_name myhost.com
> alias myhost.com
> address myhost.com
> check_command check_ssh
> In most of my hosts host_name is equal to alias and address, so it could be written like this:
> define host{
> use my-generic-host
> address myhost.com
> But it cannot be done as host_name, alias and address are necessary.
> I would like that in host_name and alias absence they would take address
> value. So I could say the same with less text making it easier to write,
> read, change, mantain, understand...
> that is all...
> txemi
> http://txemi.webhop.org
> -- System Information:
> Debian Release: 3.1
> APT prefers unstable
> APT policy: (500, 'unstable')
> Architecture: i386 (i686)
> Kernel: Linux 2.6.10-1-686
> Locale: LANG=es_ES@euro, LC_CTYPE=es_ES@euro (charmap=ISO-8859-15)
> Pkg-nagios-devel mailing list
> [email protected]
> http://lists.alioth.debian.org/mailman/ ... gios-devel
> ----- End forwarded message -----
