--=-+BQbMBL/i0TJCNmUrt0x
Content-Type: text/plain
Hi all,
For H-A cluster purpose, i need to run 2 nagios on the same host. The
problem is that config file name for cgis is hard coded.
So i added support of environment variable for cgi config file name
setting.
I hope this could be inserted in nagios dev stream.
Since i do not work with cvs snapshots, i give you a kind of "diff file"
to see what as changed (very minor) in source code.
In order to use it, you have to load apache env module and declare in
"NAGIOS/etc/apache.conf" :
SetEnv NAGIOS_CGI_CONFIG_FILE /path/to/cgi/config/filename
*** CUT diff cgiutils.c v1.2 ***
240,250d239
#define DEFAULT_CGI_CONFIG_FILE
"@sysconfdir@/cgi.cfg"
*** CUT HERE ***
*** CUT diff cgiutils.h.in v1.2 ***
389a390
> char * get_cgi_config_file_by_env(char *);
*** CUT HERE ***
Regards,
stef
Content-Type: text/html; charset=utf-8
Hi all,
For H-A cluster purpose, i need to run 2 nagios on the same host. The problem is that config file name for cgis is hard coded.
So i added support of environment variable for cgi config file name setting.
Since i do not work with cvs snapshots, i give you a kind of "diff file" to see what as changed (very minor) in source code.
In order to use it, you have to load apache env module and declare in "NAGIOS/etc/apache.conf" :
240,250d239
< /* retrieve cgi config file name first from environment variable then by parameter given from locations.h */
< char* get_cgi_config_file_by_env(char *filename)
< char *env=0;
< if( env=getenv("NAGIOS_CGI_CONFIG_FILE") )
< return env;
< return filename;
*** CUT HERE ***
*** CUT diff locations.h.in v1.2 ***
34c34
< #define DEFAULT_CGI_CONFIG_FILE get_cgi_config_file_by_env("@sysconfdir@/cgi.cfg")
> #define DEFAULT_CGI_CONFIG_FILE "@sysconfdir@/cgi.cfg"
*** CUT HERE ***
389a390
*** CUT HERE ***
Regards,
stef
--=-+BQbMBL/i0TJCNmUrt0x--
