Re: [Nagios-devel] NDOUtil-1.4b5 not working, NDOUtil-1.4b2 is fine
NDOUtils-1.4b4 also works fine using both InnoDB and MyISAM with
mysql-4.1.20-2.RHEL4.1.
Alex
Alex Burger wrote:
> With Nagios 2.8 and NDOUtils-1.4b5 configured with either a unix socket
> or TCP, I always get the following error when it attempts to log a new
> event to the database:
> Sep 20 22:05:42 server1 nagios: ndomod: Error writing to data sink!
> Some output may get lost...
> After about 15 seconds, I will then get the following (numbers change
> obviously):
> Sep 20 22:05:58 server1 nagios: ndomod: Successfully reconnected to data
> sink! 0 items lost, 193 queued items to flush.
> Sep 20 22:05:58 server1 nagios: ndomod: Successfully flushed 193 queued
> items to data sink.
> Sep 20 22:05:58 server1 ndo2db: Successfully connected to MySQL database
> The event that it attempted to log does not get written to the database.
> Usually after a few minutes the database will get updated with the
> information. I thought at first that it was adding the change 15
> seconds later, but it's usually a few minutes later even if more events
> are triggered by Nagios.
> BTW, I am checking the host status in the database with:
> select current_state, output from nagios_servicestatus where
> service_object_id IN
> (select object_id from nagios_objects where name1 = 'testserver');
> I switched back to 1.4b2 and everything works fine. When a host changes
> state, the database is updated within seconds and there are no errors in
> the log. I started with a fresh database for both versions.
> I have confirmed that all of my 'Error writing to data sink!' errors are
> coming from line 776 of ndomod.c in ndomod_write_to_sink(). From what I
> can see it is never able to write the data to the socket after it's
> received. It always has to put it in the buffer for later processing.
> I attempted to troubleshoot it by adding some additional log entries
> using ndomod_write_to_logs(), but most of the time I ended up with a
> segfault in Nagios. For example, adding the following to the top of
> ndomod_write_to_sink() will result in a segfault in both 1.4b2 and 1.4b5:
> asprintf(&temp_buffer,"ndomod: Hello!");
> ndomod_write_to_logs(temp_buffer,NSLOG_INFO_MESSAGE);
> free(temp_buffer);
> temp_buffer=NULL;
> What am I missing?
> I am runnnig Redhat EL 4 x86_64:
> Linux server1 2.6.9-42.0.10.ELsmp #1 SMP Fri Feb 16 17:13:42 EST 2007
> x86_64 x86_64 x86_64 GNU/Linux
> A user on the nagios-users list is having the same problem on both 64
> and 32 bit Linux running Nagios 2.9.
