Re: [Nagios-devel] nagios-cvs: Too many open files?
Gerd Mueller wrote:
>> Gerd, the number of temp files is extremely high. How many Nagios
>> (child) processes are running when you check the count of temp files?
>> Something seems to be amiss. Either that or you're monitoring a ton of
>> services.18837 pts/0 S+ 0:00 grep ssh
> Hm, a lot of them are are critical/down.
> nag01:/root# lsof | grep "/tmp/nagios" | wc -l
> 766
> 774
> nag01:/root# ps ax | grep /usr/local/nagios/bin/nagios
> 4548 ? Rsl 0:13 /usr/local/nagios/bin/nagios
> -d /usr/local/nagios/etc/nagios.cfg
> 18133 ? S 0:00 /usr/local/nagios/bin/nagios
> 19028 ? S 0:00 /usr/local/nagios/bin/nagios
> 19248 ? S 0:00 /usr/local/nagios/bin/nagios
> 19760 pts/0 S+ 0:00 grep /usr/local/nagios/bin/nagios
> nag01:/root# ps ax | grep /usr/local/nagios/bin/nagios -c
> 6
> 5737
> nag01:/root# ps ax | grep libexc -c
> 1
> Gerd
What do you get when you run the following command?
dir /usr/local/nagios/tmp/nagios* | wc -l
LSOF returns entries for files that have already been deleted on my
system...
nagios 4034 nagios DEL REG 3,1 1141972
/usr/local/nagios/tmp/nagios2e8Q7h
Looks like the kernel must keep references to these files even after
they've been removed. This appears to be true based on an article I
just found:
http://www.linux.com/article.pl?sid=06/10/30/1652211
There's probably a way to tweak the kernel's behavior into immediately
releasing these files once they've been deleted. Normally the kernel
keeps references to deleted files in memory (at least for a while) until
the process that deleted them exits.
Any kernel gurus out there have a solution to this?
Ethan Galstad,
Nagios Developer
Email: [email protected]
