[PATCH] core: fix possible race condition on downtime list lock, if
--------------060206040808050503010208
recently in svn head, downtime lists got locked with a new mutex, but
the unlock on downtime delete could cause possible race conditions.
see the description on the git commit attached, applies against current
HEAD.
or fetch it from over here -
https://github.com/dnsmichi/nagios-fixe ... 2d87b5c8cc
kind regards,
michael
DI (FH) Michael Friedrich
Vienna University Computer Center
Universitaetsstrasse 7 A-1010 Vienna, Austria
email: [email protected]
phone: +43 1 4277 14359
mobile: +43 664 60277 14359
fax: +43 1 4277 14338
web: http://www.univie.ac.at/zid
http://www.aco.net
Icinga Core& IDOUtils Developer
http://www.icinga.org
Content-Type: text/x-diff;
name="0001-core-fix-possible-race-condition-on-downtime-list-lo.patch"
filename*0="0001-core-fix-possible-race-condition-on-downtime-list-lo.pa";
filename*1="tch"
From 8182d64cc2fffe4b87b0f894db49892d87b5c8cc Mon Sep 17 00:00:00 2001
Date: Sat, 22 Oct 2011 15:38:21 +0200
Subject: [PATCH] core: fix possible race condition on downtime list lock, if
downtime already deleted
when deleting a downtime, the newly introduced
nagios_downtime_lock mutex gets locked to prevent
threads from fiddling in there.
after having fetched the downtime we want to delete
we try to delete only if !NULL and then releasing
the mutex.
if the possible case happens that an external module
already manipulated the list in memory and the downtime
was deleted before, the condition runs into the else-tree
returning an error. the mutex will be kept locked forever.
in order to fix that we move the unlocking outside the
if condition, let memory being free'd or result being an
error and then savely unlock the downtime list.
this will prevent us from running into a possible race
condition leaving the core idle wait for the mutex on
deleting a comment.
common/downtime.c | 7 ++++---
1 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/common/downtime.c b/common/downtime.c
index 6589bb2..48f58e9 100644
--- a/common/downtime.c
+++ b/common/downtime.c
@@ -796,9 +796,6 @@ int delete_downtime(int type, unsigned long downtime_id) {
else
last_downtime->next = next_downtime;
-#ifdef NSCORE
- pthread_mutex_unlock(&nagios_downtime_lock);
-#endif
/* free memory */
my_free(this_downtime->host_name);
my_free(this_downtime->service_description);
@@ -811,6 +808,10 @@ int delete_downtime(int type, unsigned long downtime_id) {
else
result = ERROR;
+#ifdef NSCORE
+ pthread_mutex_unlock(&nagios_downtime_lock);
+#endif
return result;
1.7.7
--------------060206040808050503010208--
