Re: [Nagios-devel] Multithreading Segfaults :(
Right but that moves out of the area of a simple patch and into something s=
ignificantly more complex.
I'm trying to avoid doing that, because we're still dealing with 2.7 here, =
but I agree with you, it's the proper way of doing it.
If this works, when my employer moves to the 3x branch, I'll look at rework=
ing it that way.
Sincerely,
Steve
________________________________________
Sent: Thursday, August 20, 2009 3:00 AM
To: Nagios Developers List
Subject: Re: [Nagios-devel] Multithreading Segfaults :(
Steven D. Morrey wrote:
> I think I've got it mostly worked out now. Turns out lots of
> functions call eachother, thereby producing a race. The trick seems
> to be to ONLY lock the sections of code dealing directly with macro_x
> and not just the entire function dealing with macro_x itself. I'm
> going to give it 12hrs of run time and then I'll get a patch up for
> testing.
The "right" way of doing that is to lock down the global arrays in a
single file and then publish a thread-safe API to manipulate it. The
thread-safeness can be taken care of by the simple expedient of adding
locks to start with, and later one can modify the functions so that
hostnames etc are added in a function-local stack-allocated array
instead, which could potentially increase performance quite a lot
(and also reduce memory fragmentation quite a bit).
OP5 AB www.op5.se
on peace.
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus =
on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
NOTICE: This email message is for the sole use of the intended recipient(s=
) and may contain confidential and privileged information. Any unauthorized=
review, use, disclosure or distribution is prohibited. If you are not the =
intended recipient, please contact the sender by reply email and destroy al=
l copies of the original message.
Original poster: ndreas Ericsson [[email protected]
