passive service (only service checks, not host checks) infos to Nagios server.
All of the clinets work well, except one (let's call it "foo", for now). After
I started the Nagios daemon, foo unexpectedly changed to "DOWN" status.
CURRENT HOST STATE: foo;DOWN;SOFT;1;(Host Check Timed Out)host is up for more 1000 days... If I understand correctly, this means that
check-host-alive runs to check foo, and (of course) return Time Out.
Other hosts which use the same configuration, is in the "PENDING" status
forever. I think foo should be in "PENDING" status, too, right?
I tried to submit passive check result for foo:
PROCESS_HOST_CHECK_RESULT;foo;0;Up! Up! Up!|Related infos:
CentOS 4.8
Nagios 3.2.3
Nagios Plugins 1.4.15
NRPE 2.12
NSCA 2.7.2
use linux-server
host_name foo
address 203.192.xx.xx
checks_enabled 0
"linux-server" is the default template of Nagios
Active Checks: DISABLED
Passive Checks: ENABLED
Obsessing: ENABLED
Notifications: ENABLED
Event Handler: ENABLED
Flap Detection: ENABLEDOther "good" hosts configuration, like bar:
use linux-server
host_name bar
address 211.147.xx.xx
checks_enabled 0
}I want to know:
1. what's the cause of this issue?
2. how can I solve this problem elegantly, so that foo can be changed to
"PENDING" status?
Thanks in advance.
