Re: [Nagios-devel] nagios silently stops
On 31 Mar 2006, at 10:06, Vadim Korsak wrote:
> Nagios 2.1 have stopped some times. Last entry in log till it stops
> - SERVICE FLAPPING ALERT:
> grep -B 1 "2.1 starting..." /var/log/nagios/nagios.log
> [1143723946] SERVICE FLAPPING ALERT: _net-n-liepaja-srv;DISK C:
> free space;STARTED; Service appears to have started flapping (20.5%
> change >= 20.0% threshold)
> [1143790405] Nagios 2.1 starting... (PID=6671)
> [1143792340] SERVICE FLAPPING ALERT: _net-n-liepaja-srv;DISK C:
> free space;STARTED; Service appears to have started flapping (21.1%
> [1143792757] Nagios 2.1 starting... (PID=11656)
> [1143793487] SERVICE FLAPPING ALERT: _net-n-liepaja-srv;DISK C:
> free space;STARTED; Service appears to have started flapping (21.6%
> [1143793561] Nagios 2.1 starting... (PID=24024)
> [1143794252] SERVICE FLAPPING ALERT: _net-n-liepaja-gw;PING
> gateway;STARTED; Service appears to have started flapping (24.2%
> [1143794282] Nagios 2.1 starting... (PID=2723)
> [1143795613] SERVICE FLAPPING ALERT: _net-n-liepaja-srv;DISK C:
> free space;STARTED; Service appears to have started flapping (21.3%
> [1143795722] Nagios 2.1 starting... (PID=27191)
> Nagios itself starts flapping ;)
Vadim,
Which platform are you running on? Which configure options did you
build with?
When it happens again, can you send a pstree output (want to see if
nagios has forked other processes - maybe hanging on an external
command). For each nagios process, can you run an strace to see what
bit of the code it is currently hanging on.
Ton
http://www.altinity.com
T: +44 (0)870 787 9243
F: +44 (0)845 280 1725
Skype: tonvoon
