Re: [Nagios-devel] Errors while testing Nagios
On 21 Oct 2010, at 23:04, Mathieu Gagn=E9 wrote:
> Hi,
> =46rom the developer guidelines [1], I ran those commands:
> ./configure --enable-libtap && make nagios && make cgis && make test
> Unfortunately, the compilation fails with the output attached =20
> (output.log) to this message. Can someone enlighten me about the =20
> cause of those errors? They are an extract from "make =20
> test_timeperiods" in ./t-tap
Can you run a make clean first?
Otherwise, which platform is this on? Tinderbox says this works on 4 =20
systems: http://tinderbox.nagios.org/nagios/status.html
(Though strangely, there is a temporary failure on test_events. I've =20
just committed more diagnostics if this happens again - could be time =20=
or server load related).
> I'm also having issues with perl tests in ./t/900-configparsing.t =20
> (test-perl.log). Am I supposed to do something to make those tests =20
> pass out of the box?
Run the diff command stated - that should show you where the =20
differences are. I've just committed a change to output the diff in a =20=
failure scenario. (My guess is that this git branch of yours contains =20=
some changes from CVS nagios)
Ton
