[Nagios-devel] NDO: Host/Services is_active flag buggy ?
--=-lPE2YQMB6+HFJxtbND6O
Content-Type: text/plain; charset=ISO-8859-15
Content-Transfer-Encoding: 8bit
on behalf of lars michelsen, who can't post to this mailinglist *g*
> Hi,
> i'm a developer of NagVis, in the actual version we have a problem
> with reading host/service states from NDO. We filter the objects with
> the flag is_active. Actualy we are not sure what the flag is used for,
> we gues it's to hold objects for historical informations in the DB.
> I just had a look at NDO-1.4b2 sources (dbhandlers.c).
> It looks like all objects in NDO are first set to is_active=0
> (function: ndo2db_set_object_as_inactive()).
> Then the up to date objects will be updated/created (Function:
> ndo2db_handle_definition). In this process all objects expect
> services and hosts run the function ndo2db_set_object_as_active() to
> set the objects to is_active=1.
> Maybe it's a bug? Maybe not. I just had a short look at the sources.
> If this is no bug, could anyone please explain what the flag is_active
> stands for and in which cases it's used?
> Regards,
> Lars
[email protected]
"In god we trust, the Rest we Monitor"
Sebastian Schubert - RHCE
Stadtsparkasse Munich
Network and IT Security
[email protected]
Stadtsparkasse München | Anstalt des öffentlichen Rechts | Amtsgericht München I HRA 75459 | Sparkassenstr. 2, 80331 München
Content-Type: text/html; charset=utf-8
i'm a developer of NagVis, in the actual version we have a problem with reading host/service states from NDO. We filter the objects with the flag is_active. Actualy we are not sure what the flag is used for, we gues it's to hold objects for historical informations in the DB.
It looks like all objects in NDO are first set to is_active=0 (function: ndo2db_set_object_as_inactive()).
Then the up to date objects will be updated/created (Function: ndo2db_handle_<objekt>definition). In this process all objects expect services and hosts run the function ndo2db_set_object_as_active() to set the objects to is_active=1.
If this is no bug, could anyone please explain what the flag is_active stands for and in which cases it's used?
Regards,
Lars
[email protected]
[email protected]
--=-lPE2YQMB6+HFJxtbND6O--
