This variable (event_broker_options=3D-1) appears in the nagios 2.x =
sample
config file, but I updated from nagios 1.4 and brought my configs with
me. I went through all the documentation found here:
http://nagios.sourceforge.net/docs/2_0/configmain.html to fix the
options that changed from 1.x to 2.x. There is nothing in there,
however, for the event broker. May I suggest a little blurb or a link
to a blurb for people using an event broker? I had no idea I was even
missing options until someone on IRC posted his config for me to
compare.
Janet.=20
-----Original Message-----
[mailto:[email protected]] On Behalf Of Ethan
Galstad
Sent: April 18, 2007 10:45 AM
To: Nagios Developers List
Subject: Re: [Nagios-devel] ndoutils and historical performance data
I'll make a note of this variable in the NDOUtils docs. Thanks!
Janet Post wrote:
> Hello,
>=20
> The nagios_instances and nagios_conninfo table issue you are
> experiencing is due to a lack of this parameter in your nagios.cfg
file:
>=20
>=20
> I spend a week trying to figure out the -exact- same problem.
>=20
> Janet.
>=20
> From: [email protected]
Florian
> Gleixner
> Sent: April 15, 2007 5:02 PM
>=20
> Hi,
>=20
> at the moment i change the table design for perfparse and therefore it
> will take some time for the next perfparse version. I also plan to
> create a NEB module to hand performance data to the perfparse daemon -
> similar like NDO module does that with the ndo2db daemon. Due to the
> similar behavior i will try to use some of the existing code of the
> ndoutils module - if the license let me reuse it (GPL?).
> Does anyone know if the NEB API is stable in Nagios 2.X and 3.X? Is
> there official documentation available?
>=20
> Btw.: Nagios 3.0a3 and ndoutils 1.4b3 seem not to work well together.
I
> did all like described in the Install instructions, nagios works well,
> but ndoutils only fills the tables nagios_instances and
nagios_conninfo.
> All other remain empty.
>=20
> Flo
>=20
>=20
> mike conigliaro wrote:
>> hey guys,
>> im working on a project for my company that generates reports/graphs
> from nagios=20
>> performance data. im currently using a combination of ndoutils and
> perfparse to=20
>> accomplish this (ndoutils for current or very recent data, and
> perfparse for=20
>> very old data). this works ok right now, but id like to get rid of
> perfparse=20
>> altogether in order to simplify my setup.
>> ndoutils works great (i love that its integrated with nagios, whereas
> perfparse=20
>> feels like a bit of a hack to me), but i was disappointed to find
that
> ndoutils=20
>> does not appear to store the parsed version of the performance data.
> ie: you=20
>> just get a field with something like this:
>> 'CPU0'=3D0%;80;95;; 'CPU1'=3D2%;80;95;;
>> this means that if i try to generate a graph from it, i need to parse
> every row=20
>> myself, which i suspect will create a pretty serious performance
> bottleneck=20
>> (especially with larger date/time ranges).
>> my question is, are there any plans to store performance data in a
way
> that is=20
>> more friendly for report generation? or am i just missing something?
Ethan Galstad,
Nagios Developer
Email: [email protected]
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
