Re: [Nagios-devel] Optimisation fix
Bob Ingraham wrote:
> This is excellent work!
> I have an old Nagios 1.2 version still running.
> Could, perhaps, send me the patch for version 1.2?
> =20
you can adapt it easily. Add the header and replace the guilty function
with my version. If you want to do it cleanly, you will have to hack the
autothings with AC_CHECK_LIB or something like that.
> That would be awesome. We have over 7,000 services being checked and o=
ur
> system is SLOOOOOW.
> =20
Just try it once, and you will see the difference. Our client loves us
now ;).
--=20
Loiseleur Michel - TM2L (08000LINUX)
LINAGORA
27, rue de Berri
1er =E9tage
75008 PARIS
T=E9l : 01 58 18 68 28
Fax : 01 58 18 68 29
"Si hoc legere scis nimium eruditionis habes"
