Re: [Nagios-devel] Nagios fails on empty config file
--=-XsMo8Pq2Y6688YIFmrWA
Content-Type: text/plain
On Wed, 2006-08-23 at 11:04 +0200, Andreas Ericsson wrote:
> Having investigated a bit further, it seems the mmap() call is the=20
> culprit in case the system doesn't support zero-length mmaps (many=20
> systems don't), in which case a simple "echo > config_file" would do the=20
> trick. Marc, can you verify if this is the case?
>=20
> The simplest solution in this case would be to just skip the mmap() step=20
> in case of zero-length files, as they're closed before real operations=20
> commence anyways, and I think it's safe to assume most systems can spare=20
> the 100 bytes or so of memory that are lost during the config reading.
i would second this suggestion. while from a development point of view
it might make sense to fail in this situation, it makes life very
difficult for packagers. also, since reading config files is a one-time
cost and the extra overhead of doing a stat+checking size seems minimal,
i don't see the harm in doing so.
sean
Content-Type: application/pgp-signature; name=signature.asc
Content-Description: This is a digitally signed message part
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2.2 (GNU/Linux)
iD8DBQBE7DZPynjLPm522B0RAgeGAJ9rS6SzFdixyt+GeITPHn0QPfzh4wCfVTRe
jt+dTqtFFi+sPpRFYHmIHW4=
=Tj/Q
-----END PGP SIGNATURE-----
--=-XsMo8Pq2Y6688YIFmrWA--
