Re: [Nagios-devel] small bug in popen_timeout_alarm_handler() in
Jason Crawford wrote:
> There is a small bug in popen_timeout_alarm_handler() in popen.c where
> it assumes that the child_process variable actually exists, and I've
> had it be NULL when the signal got sent, and had check_ping at least
> core dump. It took me 2 days, but I found the bug and patched it
> enough so it doesn't segfault anymore if the signal is sent. If
> someone wants to go further into details about how I got this crash,
> email me (on list, I'm subscribed), as it doesn't always happen, but I
> think I found the situation where I can cause that signal to be sent
> while child_process is NULL. But since accessing a pointer when it can
> possibly be NULL is always bad, here's the patch that should go in
> anyways:
Nice catch. However, the popen.c file hasn't been used for quite some
time. Try a recent release and the problem is likely to go away (or
better yet, use check_icmp which doesn't fork ping to run its check).
This is also the wrong list for nagiosplugin development. You'll have
better luck at [email protected]
OP5 AB www.op5.se
