[Nagios-devel] [PATCH] strsep does not handle 1 byte strings
--Apple-Mail-3-92811623
Content-Type: text/plain;
charset=US-ASCII;
delsp=yes;
format=flowed
Hi list,
I've noticed a problem if a subgroup has a member list with trailing
comma.
This means a string with only the separation character will be mis-
parsed by
my_strsep.
It occasionally causes errors on reload like:
Contact '' in contact group '...' is not defined anywhere
Applies to CVS HEAD.
thanks,
William
Content-Type: application/octet-stream; x-unix-mode=0644;
name=strsep_patch.diff
filename=strsep_patch.diff
--- base/utils.c
+++ base/utils.c
@@ -3050,7 +3050,7 @@ char *my_strsep (char **stringp, const c
ch=delim[0];
- if(ch=='\0')
+ if(ch=='\0' || begin[0]=='\0')
end=NULL;
else{
if(*begin==ch)
@@ -3485,7 +3485,7 @@ char *mmap_fgets_multiline(mmapfile *tem
/* one backslash found, so we should continue reading the next line */
- else if(buf[end]=='\\')
+ else if(end>=0 && buf[end]=='\\')
buf[end]='\x0';
/* else no continuation marker was found, so break */
charset=US-ASCII;
format=flowed
--Apple-Mail-3-92811623--
