Re: [Nagios-devel] [PATCH] Fix default value
On Jan 11, 2013, at 11:08 AM, Andreas Ericsson wrote:
> On 01/11/2013 02:43 PM, Ton Voon wrote:
>>=20
>> On 11 Jan 2013, at 12:17, Andreas Ericsson wrote:
>>=20
>>> On 01/10/2013 11:31 PM, Ton Voon wrote:
>>>> However, even with this set to true, it looks like Nagios 4
>>>> doesn't set the envvars. In host/service checks, it looks like no
>>>> envvars are set. Is there a technical reason why this is not
>>>> done, or is this a bug?
>>>>=20
>>>=20
>>> The technical reason is twofold: I'm lazy, and environment macros
>>> cause a lot of additional problems for anything but very small
>>> systems, while providing a mediocre benefit at best.
>>>=20
>>> The problem people have been seeing with Nagios 3 where certain
>>> checks fail to run when they add an extra service to a servicegroup
>>> is due to environment macros being enabled and the environment
>>> space being eaten.
>>>=20
>>> To enable them again means transferring the entire environment to
>>> the designated worker process, parsing it from there and setting it
>>> in a new heap which we pass to execvpe().
>>>=20
>>> Since we will always pay *all* overhead for all checks but very,
>>> very few of them use more than one or two of the variables set, the
>>> benefit really isn't worth the additional overhead.
>>=20
>> I think this "bug" is a blocker for upgrading to Nagios 4 since
>> certain checks/notification scripts/event handlers expect the
>> environment variables to be set.'
Really? I can't think of the last time I ran into a setup that the only wa=
y to use a check/script was as environment variables. It's way more effici=
ent, and I think easier, to just pass the few params you normally need as c=
ommand-line options. Even for things like Oracle I just set local env opti=
ons in the script or use one of the scripts that lets you pass in what ORAC=
LE_HOME and stuff should be.
Dan
