[email protected] wrote:
> Has anyone had problems obtaining core dumps from the main Nagios daemon
> when it segfaults?
> I've enabled the option in the config file "daemon_dumps_core" but, after
> the daemon dies due to a segfault (confirmed via dmesg,) a core file never
> seems to be produced.
> And yes, I've set the global ulimit for core dumps to unlimited, and yes,
> there is enough space on my disk, and yes, I've scoured the disk with
> "find" looking for files with the name of "core" or "core.", but to
> no avail.
> I also completely disabled the segfault handling logic in the signal
> handler, but nothing's changed.
> What am I missing here?
Is Nagios' working directory writable by the user Nagios runs as?
> I'm considering running nagios in the foreground (non-daemon mode) just to
> see if I can catch the magically-missing core file.
Make sure you start it in a directory where you and the nagios
pseudo-user has write permissions.
OP5 AB www.op5.se
