Dmitry Sivachenko wrote:
>>>I am unable to entirely leave check_command parameter in the case when
>>>I derive this host definition from another which did use check_command.
>>Create another template, identical in all aspects except for the lack of
>>a check_command and use that for the hosts that shouldn't have one.
>>>I want to be able to redefine check_command to empty value.
>>You can not.
> I see. But you suggest an ugly workaround.
> The ability to redefine check_command to an empty value permits to create
> much more elegant config files for nagios.
So patch it, or find a way to work around it.
> BTW, it is documented.
It is a bad phrasing in the documentation. "empty check_command" should
really read "no check_command variable at all", which is what it means.
OP5 AB www.op5.se
