[Nagios-devel] Nagios 3.3.1 is not processing performance data
Hi, everybody.
I=B4ve installed Nagios 3.3.1 and noticed that it is not processing
performance data when it is null.
This is a big problem for me, because I use the performance process to
send data to my central servers, instead of de ocsp command, as this
command makes the latency increase a lot.
When I made the downgrade to Nagios 3.2.3 everything works fine.
Can someone help me? Was the Nagios Core code modified? I didn=B4t find
anything on the release change log.
Thanks.
