Re: [Nagios-devel] Default argument values for nagios check commands
On 11/04/2010 03:50 PM, Bostjan Skufca wrote:
> I was wondering if it is possible (or would be easy to implement) defau=
lt
> values for nagios check commands.
Well, if you don't mind the extra subshells, it's already "implemented":
# tail -22 commands-misc.cfg
command_name check_defaults
command_line echo "OK - value A is `echo $ARG1$ 2000 | awk '{
print $$1 }'`, value B is `echo $ARG2$ 5000 | awk '{ print $$1 }'`"
host_name Nagios
service_description Defaults - 0
check_command check_defaults
host_name Nagios
service_description Defaults - 1
check_command check_defaults!foo
host_name Nagios
service_description Defaults - 2
check_command check_defaults!foo!bar
# grep value ../../var/spool/status.dat
plugin_output=3DOK - value A is 2000, value B is 5000
plugin_output=3DOK - value A is foo, value B is 5000
plugin_output=3DOK - value A is foo, value B is bar
Kind regards,
J. Bern
--=20
7
Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver Mic=
hel
