Re: [Nagios-devel] Sourceforge cvs-server in trouble?
Sourceforge are upgrading their CVS:
"- Developer CVS check-in/check-out is getting a major speed
increase in the next 5 weeks. Anonymous check-out has been performing
great and soon SSH check-ins/check-outs will have similar speeds. With
this upgrade are also eliminating the 5 to 8 hour delay that currently
exists between developer check-in and anonymous check-outs. Everything
will be in real-time. This means as soon as you make a code change,
your users can grab the latest code. This will mark the completion
of our long-term CVS infrastructure improvement project."
I guess this might have an effect...
Ben
jeff vier wrote:
> I get the exact same error. I was going to send an email to the list
> today also if it hadn't cleared up. I guess it hasn't. :(
> On Thu, 2004-06-03 at 02:17, Andreas Ericsson wrote:
>>I'm having trouble running cvs update and cvs checkout on the nagios
>>dist at sourceforge.
>>Is this a known issue (no notes about it at sourceforge site), or am I
>>the only one experiencing it?
>>I get
>>$ cvs -d:pserver:[email protected]:/cvsroot/nagios login
>>Logging in to :pserver:[email protected]:2401/cvsroot/nagios
>>CVS password:
>>cvs [login aborted]: unrecognized auth response from
>>cvs.sourceforge.net: M PserverBackend::PserverBackend() Connect
>>(Connection refused)
>>I've tried with cvs versions 1.12.5 and 1.11.5, but none seem to work.
> This SF.Net email is sponsored by the new InstallShield X.
>>From Windows to Linux, servers to mobile, InstallShield X is the one
> installation-authoring solution that does it all. Learn more and
> evaluate today! http://www.installshield.com/Dev2Dev/0504
> Nagios-devel mailing list
> [email protected]
