[Nagios-devel] [PATCH] NODutils: Duplicate lines in servicechecks
As remarked in the other thread, the unique constraints for the table
nagios_servicechecks is missing causing duplicate rows. This patch
removes the KEY defines and adds an unique key just like
nagios_hostchecks has defined too.
As I am not sure in which file you will put the ALTER statements since
1.4b9 is out already, I'll attach those statements as is.
diff --git a/db/mysql.sql b/db/mysql.sql
index 3036f46..386a460 100644
--- a/db/mysql.sql
+++ b/db/mysql.sql
@@ -1004,9 +1004,7 @@ CREATE TABLE IF NOT EXISTS `nagios_servicechecks` (
`long_output` TEXT NOT NULL default '',
`perfdata` TEXT character set latin1 NOT NULL default '',
PRIMARY KEY (`servicecheck_id`),
- KEY `instance_id` (`instance_id`),
- KEY `service_object_id` (`service_object_id`),
- KEY `start_time` (`start_time`)
+ UNIQUE KEY `instance_id`
(`instance_id`,`service_object_id`,`start_time`,`start_time_usec`)
) ENGINE=MyISAM COMMENT='Historical service checks';
ALTER table nagios_servicechecks DROP KEY instance_id;
ALTER table nagios_servicechecks DROP KEY service_object_id;
ALTER table nagios_servicechecks DROP KEY start_time;
ALTER table nagios_servicechecks ADD UNIQUE KEY `instance_id`
(`instance_id`,`service_object_id`,`start_time`,`start_time_usec`);
I've tested the patch and everything works fine now - no more duplicate
rows.
Kind regards,
Michael
DI (FH) Michael Friedrich
[email protected]
Tel: +43 1 4277 14359
Vienna University Computer Center
Universitaetsstrasse 7
A-1010 Vienna, Austria
