[Nagios-devel] nagios with embedded perl 5.8.9 in FreeBSD
Hi:
First subscribing to this list, just to submit a patch and to say nice work.
Nagios 3.0.6 with Perl 5.8.9 on FreeBSD throws a signal bus when starting.
gdbing the code I opened a pr on FreeBSD site:
http://www.freebsd.org/cgi/query-pr.cgi?pr=131993&cat=
But after that, reviewing the code, there is something wrong with a
local variable initialization. Jesus, take a look at embedding
"variable" on init_embedded_perl() funcion on utils.c!!
Here is my patch to correct the problem. Hope it helps.
Sebastian Guarino
--- utils.c-old 2009-02-23 15:36:28.000000000 -0200
+++ utils.c 2009-02-23 16:00:51.000000000 -0200
@@ -3597,7 +3597,7 @@
/* initializes embedded perl interpreter */
int init_embedded_perl(char **env){
#ifdef EMBEDDEDPERL
- char *embedding[]={ "", "" };
+ void **embedding;
int exitstatus=0;
char *temp_buffer=NULL;
int argc=2;
@@ -3612,8 +3612,11 @@
else{
- embedding[1]=p1_file;
+ embedding = (void **)malloc(2*sizeof(char *));
+ if(embedding==NULL)
+ return ERROR;
+ *embedding=strdup("");
+ *(embedding+1)=strdup(p1_file);
use_embedded_perl=TRUE;
