Re: [Nagios-devel] Mass define servicedependency for NRPE services
Hash: SHA1
On 02/09/09 05:40 PM, Mathieu Gagné wrote:
>>> Hi,
>>>> Just add the host_name or hostgroup_name directive (you can put all
>>>> hostgroups for instance, or enable wildcards and use *) and you're set.
>>> Unfortunately, it doesn't work. This explains why I asked the
>>> mailinglist. If I do as you suggested, all NRPE based services will be
>>> depending on the NRPE service on ALL hosts. (not only their
>>> respective host)
>>> Here is my servicedependency definition:
>>> define servicedependency {
>>> hostgroup_name hosts-with-nrpe
>>> service_description NRPE
>>> dependent_servicegroup_name nrpe-services
>>> execution_failure_criteria n
>>> notification_failure_criteria c,u
>> And what result you get with that? I have pretty much the same, but with
>> a "dependent_service_name" directive, and it should do the same. If it
>> don't, it's a bug.
> So I guess it's a bug or it wasn't initially planned to work that way.
> You will find attached to this message a patch against Nagios 3.0.6 that
> should fix this bug.
> This servicedependency definition should now work:
In the patch I'm talking about you would still need a host_name or
hostgroup_name directive - usually the same one that is defined on any
of your NRPE service definition. I don't see why you would want to take
it out either...
i.e.:
hostgroup_name linux-servers
blah blah blah...
service_description Load
servicegroups nrpe-services
blah blah blah...
Then on each host, "Load" (and any other service in nrpe-services)
becomes dependent of NRPE on the same host. Is that working?
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFKnxu86dZ+Kt5BchYRAmyPAKCN8oyJBvenBVI5Zo6opVPiutYSPACgtDOh
wP6tmJTv6GfZHyFQIddQhzc=
=wyfM
-----END PGP SIGNATURE-----
