I have converted xodtemplate_service_list, service_list, and host_list to a
chained hash from a linked list because I was seeing a scaling problem in
1.0b6 with 1800 hosts, each with 2 services.
I saw anywhere from a 33% to 75% speedup with this patch. Detailed numbers
and the patch are available at:
http://dan.drown.org/nagios/
The numbers for time /usr/local/bin/nagios /usr/local/etc/nagios/nagios.cfg
are misleading because they include all cpu used by child processes. The
gprof output shows that a significant difference in user cpu used (around 50%
less). vmstat output was noticably different between the two runs, 10-20% cpu
idle with the patch, 0-10% idle without.
These tests were run on a 2xP3 930mhz, 1gb ram.
The details of the patch:
I removed the extra argument to find_host and find_service (this wasn't used
anywhere in the code)
I removed extern references to xodtemplate_service_list, service_list, and
host_list outside of the .c files their helper functions were defined in.
new functions:
move_first_service() moves a static pointer to the head of
service_list
get_next_service() returns the current service and moves
the static pointer to the next
find_all_services_by_host(char *host) sets up get_next_service_by_host to
return all services that host
has
get_next_service_by_host() returns host's next service
move_first_host()
get_next_host()
- like move_first_service, and
get_next_service
get_host_cursor() returns an allocated cursor to iterate
through host_list
get_next_host_cursor(void *v_cursor) returns the next host using the cursor
free_host_cursor(void *cursor) frees the cursor
get_xodtemplate_service_cursor()
get_next_xodtemplate_service(void *v_cursor)
free_xodtemplate_service_cursor(void *cursor)
- like get_host_cursor,
get_next_host_cursor,
and free_host_cursor
get_next_N(..) helper function to do the work for
get_next_*
It's looking like if MySQL AB doesn't make a movie based on the manual,
nobody's ever gonna learn how to use a database.
- r.
