------=_NextPart_000_0001_01C28A59.AF89A0B0
Content-Type: text/plain;
charset="us-ascii"
Hey guys,
I'm just getting started with Nagios and have been very impressed with
what I see so far. I am having one problem though.
I've followed the guidelines for setting it up to the letter.
Everything compiled and ran without any errors on the first try (hey!
There's a first time for everything).
My problem is this:
Once I log into the web portal using nagiosadmin, it comes
up fine. If I try to click on any of the tools however, I get the
following message:
It appears as though you do not have permission to view process
information...
If you believe this is an error, check the HTTP server authentication
requirements for accessing this CGI
and check the authorization options in your CGI configuration file.
I've checked all my permission and authentication settings in my config
files and everything seems to match the documentation.
What am I doing wrong?
Justin A. Diana
Director of Operations
DataCraft Solutions, Inc.
www.datacraftsolutions.com
Content-Type: text/html;
charset="us-ascii"
Clean
Clean
DocumentEmail
MicrosoftInternetExplorer4
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Hey guys,</font
...[email truncated]...
