Re: [Nagios-devel] Segfault during pre-flight check
Hi Thomas -
Can you try the following to generate a backtrace? This would be
helpful in tracking down the problem...
1. Use the non-stripped nagios binary (located in the base/ subdir of
the Nagios distro) for this procedure. If you're using an RPM install,
get the source and compile it for yourself first.
2. From the command line...
cd /base
gdb nagios
3. From within gdb..
run -v /etc/nagios/nagios.cfg
4. Once it segfault, gdb will stop and display an error message. Use
the following command from within gdb to get a backtrace and see where
they problem occurred...
bt
Send the output to (preferably) the list, or directly to myself if you'd
like. Thanks!
Thomas Guyot-Sionnest wrote:
> Hi,
> I'm maintaining a pretty big nagios setup (about 60 hosts/ 600 services and
> plan to grow that by 3-4 times). Most of the config is using templates to
> save config lines and maintenance time. Every host has an extinfo (one
> definition for each hostsgroup).
> Now I started adding services extinfos to do some fancy things with e-mail
> pages, and ran in a strange segfault bug. To explain it better I'll give an
> overview of my config.
> check
[snip]
> I'm sorry I didn't have time to cleanup all the config . I'm currently
> setting another nagios box, so if I run into this problem at the very
> beginning I'll keep that config and send it over. I also tried to get a core
> dump but it didn't worked, I'm not sure if I need to enable some options at
> compile time...
> Thanks
> Thomas
Ethan Galstad,
Nagios Developer
Email: [email protected]
