--Apple-Mail-16-254030996
Content-Type: text/plain;
charset=US-ASCII;
format=flowed
So far everything indicates that I am dealing with a bug in the NSCA
code running on OS X Panther. Attached is a ktrace of nsca (--single)
receiving a send_nsca.
The bug prevents nsca from functioning at all...
On Jan 23, 2004, at 9:52 AM, Marc Powell wrote:
>> 22499 nsca RET sendto 59/0x3b
>> 22499 nsca CALL select(0x7,0xbffff280,0xbffff300,0xbffff380,0)
>> 22499 nsca RET select 1
>> 22499 nsca CALL sendto(0x5,0xbfffe680,0x3b,0,0,0)
>> 22499 nsca GIO fd 5 wrote 59 bytes
>> "Jan 22 16:21:37 nsca[22499]: Handling the connection..."
> Just FYI, this indicates that nsca _is_ sending more data to a syslog
> log file but there isn't enough information to determine which.
I don't know where it's writing "Host address checks out ok" though
which is also in the ktrace output Also the "Connection from 127.0.0.1
port 50882" output is not written to the syslog even though it's in the
ktrace.
I do know where it's writing the other entries. It's in the
/var/log/system.log which is the systems main syslog. This is the same
syslog that nagios writes to (nagios.log also). With debug=1, in the
syslog all I get is:
Jan 27 01:33:08 MyTiBook nsca[14231]: Handling the connection...
Jan 27 01:33:08 MyTiBook nsca[14231]: End of connection...
and in nagios.log I get nothing. It seems pretty clear that there is
never any external commands sent from nsca. Even if I send an external
command that contains totally bogus info, I would still see them in
both syslog and nagios.log:
Yet nothing is ever seen when send_nsca sends data. Also, I have
alternate_dump_file=/Users/nagios/var/rw/nsca.dump and that file is
never even created.
>> 22499 nsca CALL fcntl(0x6,0x3,0xbffff410)
>> 22499 nsca RET fcntl 2
>> 22499 nsca CALL fcntl(0x6,0x4,0x5)
>> 22499 nsca RET fcntl 0
>> 22499 nsca CALL open(0x6d28,0,0x1b6)
>> 22499 nsca NAMI "/dev/urandom"
>> 22499 nsca RET open 7
>> 22499 nsca CALL fstat(0x7,0xbffff0a0)
>> 22499 nsca RET fstat 0
>> 22499 nsca CALL ioctl(0x7,FIODTYPE,0xbffff0f0)
>> 22499 nsca RET ioctl 0
>> 22499 nsca CALL read(0x7,0x14000,0x20000)
>> 22499 nsca GIO fd 7 read 131072 bytes
>> "\^E\M-%\M-Z|\M^S\M-O\M-a\M-D\M-j\M-h\M-h;A\M-9\M-e\M^Zc\^D\M-2\M^E\M-
>> m})\^F\M-4\0\^C\M-%\^_1\M-f\M^\\M-j\M-_\M-\4e\M-o\M^Bl\M-Mb\M-_'{M\
>> > the encrptoed data...
> Yup. 131K seems to be an awful lot but it could certainly be attributed
> to the encryption method you are using. Just as a test, I would
> probably
> try using just simple XOR.
It was and still is set to XOR... decryption_method=1
>> 22499 nsca RET sendto 132/0x84
>> 22499 nsca CALL recvfrom(0x6,0xbfffee70,0x2d0,0,0,0)
>> 22499 nsca GIO fd 6 wrote 0 bytes
>> 22499 nsca RET recvfrom 0
>> 22499 nsca CALL sendto(0x5,0xbfffe170,0x35,0,0,0)
>> 22499 nsca GIO fd 5 wrote 53 bytes
>> "Jan 22 16:21:37 nsca[22499]: End of connection..."
> This is actually saying -- "End of connection or could not read request
> from client..." If you can increase the number of characters that
> ktrace
> displays you should see that (it's -s 512 for strace to display 512
> characters for example).
Not sure what you mean here. As far as I know, ktrace is displaying all
characters. I only sent you a portion of what I captured, but made sure
that it was a complete transaction. I edited out the
"M-h;A\M-9\M-e\M^Zc" lines to save on readability.
> This is really a symptom of whatever the problem is, but it appears
> that
> it might be strictly a communication problem. Looking at the code, the
> pertinent section is:
> /* process all data we get from the
...[email truncated]...
