Cary Petterborg wrote:
> I have one question and one observation in addition to what I already
> said....
> Question:
> In the case of the web server and nagios being on the same system, how
> much is an fsync() really going affect the performance of the system?
> Can someone "quantify" the impact of a single fsync? (I guess that is
> technically a second question.) If it were to do a sync() (where all the
> open files are checked to ensure that they are sync'd) instead of an
> fsync(), I would definitely agree - much bigger impact. But, the single
> fsync at the end of writing a file should not be of any real
> significance, except in the case where it means that the data is
> actually there where it should be if it *is* done (e.g. my case).
I tried a program which I meant to attach to this mail that I deleted by
mistake as I was composing this mail, that fopen'd a file, wrote a
character at a time and either fclosed at the end, or fsync'd after each
character, or sync'd after each character. it wrote 1MB worth of
characters to the file.
this was the results on a ubuntu 9.04 dell m6300 laptop that was
relatively idle at the time.
(no sync or fsync):
hirenp@firebird:/tmp$ time ./a.out
real 0m0.122s
user 0m0.108s
sys 0m0.008s
(no sync or fsync with a "dd if=/dev/random of=/tmp/test2 bs=1M
count=100" running in another terminal)
real 0m0.052s
user 0m0.048s
sys 0m0.004s
(fsync)
hirenp@firebird:/tmp$ time ./a.out ; echo $?
real 0m2.422s
user 0m0.244s
sys 0m0.784s
0
(fsync with a dd "if=/dev/random of=/tmp/test2 bs=1M count=100" running
real 0m2.037s
user 0m0.248s
sys 0m0.872s
0
(sync - had to be interrupted, progress 5% on stop)
^C
real 8m15.111s
user 0m0.084s
sys 7m59.070s
(sync with a "if=/dev/random of=/tmp/test2 bs=1M count=100" running in
another terminal - had to be interrupted, progress 5% on stop)
^C
real 8m11.002s
user 0m0.100s
sys 7m54.726s
not sure how useful this really is to get an idea, but sync is clearly
to be avoided as you mentioned. what do you guys make of the difference
between fsync and no fsync in relation to nagios?
> Observation:
> I think that the retention.dat and other files that are important to
> retain across crashes would definitely benefit from the fsync. Though
> nagios would still work across such a failure, I would rather that data
> be preserved properly, especially when we have a retention.dat file that
> is 40MB and the rescheduling, etc. would be handled so much more
> effectively. So for what it is worth, I think it important that those
> files be fsync'd.
