Re: [Nagios-devel] [RFC] - NDOUtils duplicate lines problem
--00151747b4d22f096a0480f29403
Content-Type: text/plain; charset=ISO-8859-1
I am using innodb. I have worked with Hendrik's prescribed solution on a
very small installation of nagios and it appears to hold. I hope to do the
bigger dump over weekend and hope for the best. Thanks for all your help on
this.
On Wed, Mar 3, 2010 at 4:42 PM, Michael Friedrich wrote:
> shadih rahman wrote:
> > Michael,
> > Thanks for your responds. Now if I upgrade to 1.4b9, would that fix
> > the problem for future queries.
> Looking at CVS head there is no such fix applied.
> but you define those unique keys yourself anyways - just small parts to
> do and already mentioned in a post some while ago by hendrik.
> > I can deal with existing data later. Please advise on this. Thanks
> 46 gb is a bunch of data. and that within mysql. are you using myisam or
> innodb? and did you think about moving to postgres/oracle?
> DI (FH) Michael Friedrich
> [email protected]
> Tel: +43 1 4277 14359
> Vienna University Computer Center
> Universitaetsstrasse 7 A-1010 Vienna, Austria
> Download Intel® Parallel Studio Eval
> Try the new software tools for yourself. Speed compiling, find bugs
> proactively, and fine-tune applications for parallel performance.
> See why Intel Parallel Studio got high marks during beta.
> http://p.sf.net/sfu/intel-sw-dev
> Nagios-devel mailing list
> [email protected]
Cordially,
Shadhin Rahman
Content-Type: text/html; charset=ISO-8859-1
I am using innodb.=A0 I have worked with Hendrik's prescribed solution =
on a very small installation of nagios and it appears to hold.=A0 I hope to=
do the bigger dump over weekend and hope for the best.=A0 Thanks for all y=
our help on this.
On Wed, Mar 3, 2010 at 4:42 PM, Michael Frie=
> Michael,
> =A0 =A0Thanks for your responds. =A0Now if I upgrade to 1.4b9, would t=
hat fix
> =A0 =A0 I can deal with existing data later. =A0Please advise on this.=
=A0Thanks
46 gb is a bunch of data. and that within mysql. are you using myisam=
or
michael.friedrich@univie.=
ac.at
http://p.sf.=
[email protected]=
urceforge.net
<a href=3D"https://lists.sourceforge.net/lists/listinfo/n
...[email truncated]...
