[Nagios-devel] Re: [Nagios-users] configure Holidays
Am Mittwoch, 11. Februar 2004 21:52 schrieb Subhendu Ghosh:
> On Fri, 6 Feb 2004, Andreas Koch wrote:
> > Hello nagios-frend's,
> > how I can adjust in timeperios.cfg that at holidays is also informed.
> > Does it does give there an adjustable solution, or must I programming?
> Sorry - network monitoring folks don't get holidays. you must always bring
> your pager and cellphone and a can with a string attached :)
> Reality: Nagios does not deal with the calendar only wekdays.
> If you are having a holiday - depending on what you want, you might have a
> script add downtime to all the hosts to prevent notifications..
a little question:
what's the difference between contacs and host in nagios-objects?
Scheduled-downtime could be set as a fixed downtime for a long time, so i
think it's possible for the fabuluos nagios-programmers to implement a
scheduled-downtime for all objects (might be imlemented in Nagios 2.x).
Today we handle this problem in configuring contacts, each admin is member of
a contactgroup, so we have to delete / comment his pager-number, so they
don't get sms in their holidays, but they receive the mails from nagios, so
they are able to know what's happend in holiday times ...
Regards
Michael
Diese E-Mail wurde auf Viren ueberprueft.
www.mimesweeper.com
