[Nagios-devel] Error in NDOUtils
In my log:
[1190402216] Nagios 3.0b3 starting... (PID=30497)
[1190402216] LOG VERSION: 2.0
[1190402216] ndomod: NDOMOD 1.4b5 (08-29-2007) Copyright (c) 2005-2007 Ethan
Galstad ([email protected])
[1190402216] ndomod: I've been compiled with support for revision 305 of the
internal Nagios object structures, but the Nagios daemon is currently using
revision 306. I'm going to unload so I don't cause any problems...
[1190402216] Error: Function nebmodule_init() in module
'/usr/local/nagios3/bin/ndomod-3x.o' returned an error. Module will
be unloaded.
If edit e recompile:
include/nagios-3x/objects.h:#define CURRENT_OBJECT_STRUCTURE_VERSION 306
/* increment when changes are made to data structures... */
Not work too.
___________________________________________________________________________________
Para fazer uma ligação DDD pra perto ou pra longe, faz um 21. A Embratel tem
tarifas muito baratas esperando por você. Aproveite!
