Re: [Nagios-devel] Event Profiler Timers?
Steven D. Morrey wrote:
> Hi Everyone,
> I've been taking a long hard look at my event profiling code and I had a thought.
> We're currently using time(&time_t) to get the function entry and exit times but is this really precise enough?
It really isn't. I expect most events complete in a lot less than a
second, yielding a skewed picture of what Nagios spends its time on.
On a side-note, time_t = time(NULL) is slightly faster in nearly
all circumstances since it doesn't require the extra seek+write
access to the RAM banks.
> Would it be better (i.e. worth the overhead), to use clock_t
> = clock() to get the entry and exit?
Could be. But then we might as well use gettimeofday() from the start
so the wrap-around case at least gets exercised a lot instead of
every 72 minutes.
Do as you please though. I doubt if I will use this feature
myself, and once it's in place it's easier for others to extend
upon later.
OP5 AB www.op5.se
on peace.
