I have applied the last patch to current CVS head... it works so far.
Hope this doesn't break anything...
Best wishes
Hendrik
Joerg Linge schrieb:
> Am Samstag, 28. Oktober 2006 20:04 schrieb Joerg Linge:
>> Am Samstag, 28. Oktober 2006 19:43 schrieb Joerg Linge:
>>> Hi Ethan, hi List
>>> the latest CVS HEAD does not compile with --enable-embedded-perl
>> Here is a possible Patch
>> "make all" returns no errors. I will check the function tomorrow
> Next try ....
> With the first patch Nagios will compile but i get a SIGSEV after 2 secounds
> Now the function works correct. ePN can now be disabled per plugin.
> Jörg
> diff -u nagios-cvs/base/utils.c nagios-cvs-fixed/base/utils.c
> --- nagios-cvs/base/utils.c 2006-10-28 00:51:26.000000000 +0200
> +++ nagios-cvs-fixed/base/utils.c 2006-10-30 11:21:31.000000000 +0100
> @@ -2401,6 +2401,7 @@
> STRLEN n_a ;
> char *perl_output;
> int count;
> + int is_perl=FALSE;
> int use_epn=FALSE;
> #ifdef aTHX
> dTHX;
> @@ -4943,7 +4944,6 @@
> char line1[80]="";
> char line2[80]="";
> int is_perl=FALSE;
> - int use_epn=FALSE;
> int found_epn_directive=FALSE;
> if(enable_embedded_perl==TRUE){
> @@ -4958,15 +4958,15 @@
> /* yep, its a Perl script... */
> if(strstr(line1,"/bin/perl")!=NULL){
> - isperl=TRUE;
> + is_perl=TRUE;
> /* second line MAY tell us explicity whether
> or not to use embedded Perl */
> if(fgets(line2,80,fp)){
> - if(strstr(buffer,"#USE_EPN")==buffer){
> + if(strstr(line2,"#USE_EPN")!=NULL){
> use_epn=TRUE;
> found_epn_directive=TRUE;
> - else
> if(strstr(buffer,"#NO_EPN")==buffer){
> + else if(strstr(line2,"#NO_EPN")!=NULL)
> use_epn=FALSE;
> Using Tomcat but need to do more? Need to support web services, security?
> Get stuff done quickly with pre-integrated technology to make your job easier
> Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
> http://sel.as-us.falkag.net/sel?cmd=lnk ... dat=121642
> Nagios-devel mailing list
> [email protected]
