Re: [Nagios-devel] Problem compiling nagios 2.3.1
Andrea Gabellini wrote:
> Hi,
> I'm using various solaris versions, from 5.7 to 5.10.
> An usable header file is iso/limits_iso.h except for solaris 5.7 where
> the header fiele is limits.h.
> As a workaround I'm using, in cgi/getcgi.c:
> #ifndef INT_MAX
> #define INT_MAX 2147483647
> #endif
A more portable way is to write
#ifndef CHAR_BIT
# define CHAR_BIT 8 /* true for any system created post-woodstock */
#endif
#ifndef INT_MAX
# define INT_MAX (1 < ((sizeof(int) * CHAR_BIT) - 1))
#endif
which always gets it right and works no matter the bitwidth of int on
your system.
The way with a fixed number will appear to work where int is 64-bit, but
can break subtly in an almost completely undebuggable way.
OP5 AB www.op5.se
