[Nagios-devel] [PATCH] Fix some minor memory leaks
--=-W1NtOoxyd/ipG+s37I7E
Content-Type: text/plain
There are some instances where asprintf() are used to construct strings
but the resulting allocated memory isn't ever free()d. This patch
(against Nagios 3.2.0) makes sure that the strings allocated by asprintf
are freed when they are no longer needed.
Sean
Content-Disposition: attachment; filename="nagios-fix-asprintf-leaks.patch"
Content-Type: text/x-patch; name="nagios-fix-asprintf-leaks.patch";
charset="UTF-8"
diff --git a/base/nebmods.c b/base/nebmods.c
index acf7cc4..c6945d5 100644
--- a/base/nebmods.c
+++ b/base/nebmods.c
@@ -244,8 +244,10 @@ int neb_load_module(nebmodule *mod){
logit(NSLOG_RUNTIME_ERROR,FALSE,"Error: Could not delete temporary file '%s' used for module '%s'. The module will be unloaded: %s\n",output_file,mod->filename,strerror(errno));
neb_unload_module(mod,NEBMODULE_FORCE_UNLOAD,NEBMODULE_ERROR_API_VERSION);
+ my_free(output_file);
return ERROR;
/* find module API version */
#ifdef USE_LTDL
diff --git a/base/netutils.c b/base/netutils.c
index 443bc91..fabad77 100644
--- a/base/netutils.c
+++ b/base/netutils.c
@@ -47,6 +47,7 @@ int my_tcp_connect(char *host_name, int port, int *sd, int timeout){
asprintf(&port_str,"%d",port);
result=getaddrinfo(host_name,port_str,&hints,&res);
+ my_free(port_str);
if(result!=0){
/*printf("GETADDRINFO: %s (%s) = %s\n",host_name,port_str,gai_strerror(result));*/
return ERROR;
diff --git a/base/utils.c b/base/utils.c
index ad4b627..726f307 100644
--- a/base/utils.c
+++ b/base/utils.c
@@ -4444,6 +4444,7 @@ int query_update_api(void){
char *api_query=NULL;
char *api_query_opts=NULL;
char *buf=NULL;
+ char *buf2=NULL;
char recv_buf[1024];
int report_install=FALSE;
int result=OK;
@@ -4471,19 +4472,32 @@ int query_update_api(void){
/* generate the query */
- asprintf(&api_query,"v=1&product=nagios&tinycheck=1&stableonly=1");
- if(bare_update_check==FALSE)
- asprintf(&api_query,"%s&version=%s%s",api_query,PROGRAM_VERSION,(api_query_opts==NULL)?"":api_query_opts);
+ asprintf(&buf2,"v=1&product=nagios&tinycheck=1&stableonly=1");
+ if(bare_update_check==FALSE) {
+ asprintf(&api_query,"%s&version=%s%s",buf2,PROGRAM_VERSION,(api_query_opts==NULL)?"":api_query_opts);
+ my_free(buf2);
+ } else {
+ api_query = buf2;
/* generate the HTTP request */
asprintf(&buf,"POST %s HTTP/1.0\r\n",api_path);
- asprintf(&buf,"%sUser-Agent: Nagios/%s\r\n",buf,PROGRAM_VERSION);
- asprintf(&buf,"%sConnection: close\r\n",buf);
- asprintf(&buf,"%sHost: %s\r\n",buf,api_server);
- asprintf(&buf,"%sContent-Type: application/x-www-form-urlencoded\r\n",buf);
- asprintf(&buf,"%sContent-Length: %d\r\n",buf,strlen(api_query));
- asprintf(&buf,"%s\r\n",buf);
- asprintf(&buf,"%s%s\r\n",buf,api_query);
+ asprintf(&buf2,"%sUser-Agent: Nagios/%s\r\n",buf,PROGRAM_VERSION);
+ my_free(buf);
+ asprintf(&buf,"%sConnection: close\r\n",buf2);
+ my_free(buf2);
+ asprintf(&buf2,"%sHost: %s\r\n",buf,api_server);
+ my_free(buf);
+ asprintf(&buf,"%sContent-Type: application/x-www-form-urlencoded\r\n",buf2);
+ my_free(buf2);
+ asprintf(&buf2,"%sContent-Length: %d\r\n",buf,strlen(api_query));
+ my_free(buf);
+ asprintf(&buf,"%s\r\n",buf2);
+ my_free(buf2);
+ asprintf(&buf2,"%s%s\r\n",buf,api_query);
+ my_free(buf);
+ buf=buf2;
printf("SENDING...\n");
--=-W1NtOoxyd/ipG+s37I7E--
