Hi Ingo,
Ingo Lantschner schrieb:
> But to my understanding of the tag "#nagios: -epn" it should disable
> epn for the particular plugin even if use_embedded_perl ist set to 1.
> But unfortunately the output still gets messed up.
yes - this should do the trick, but after regarding the docs it should be
"# nagios: -epn" instead of
"#nagios: -epn"
There is a blank between '#' and 'n'.
Regards,
Hendrik
