Re: [Nagios-devel] Multilanguage support
On 17 Jan 2003 at 0:17, Subhendu Ghosh wrote:
> > >On 15 Jan 2003, Karl DeBisschop wrote:
> > >>Plugin internationalization would be wanted too, I would guess?
> > Yes, unless it doesn't cause troubles to addons and misc. But it
> > shouldn't be the case if the only parsed parts are performance stats.
> > >Long term - yes (are there any issues - perf: disk i/o - or security with
> > >passing possibly unicode strings through pipes)
> > I guess it could be made optional.
> > >Short term - move the "OK/WARN/CRIT/UNKWN" tags to be prepended to the
> > >plugin output based on the i18n of return code.
> > I'm not sure to understand what you mean here. Could you please elaborate?
> Currently a number of the plugins output is written out as "OK: status"
> We could remove the OK - leave the status - and have the web interface
> prepend the OK in i18n to the status before display.
Perhaps the OK/WARN/CRIT/UNKWN tags should be stripped altogether?
Relying on the web interface to generate the tags is okay when using
a web browser, but they'll be missing in the logs, notifications,
etc.
Ethan Galstad,
Nagios Developer
Email: [email protected]
