Re:Re: [Nagios-devel] Initial Scheduling Problem explanation--
[email protected] wrote:
This is also in the archives. I do remember the post to the whole group.
though not sure if it was directed to the Nagios-user list instead.
since im part of both groups, :-D
have a nice day.
> --__--__--
> Message: 6
> Date: Wed, 24 Jul 2002 10:06:56 -0600
> From: Darren Gamble
> Subject: Re: [Nagios-devel] Initial Scheduling Problem explanation
> To: [email protected]
> Cc: 'Russell Scibetti' ,
> "'[email protected]'"
> Good day,
> Thanks for forwarding me this message, Russell, and thanks Bill, for taking
> the time to help a user.
> > Russell, I am surprised that someone hasn't answered this by now,
> > so let me give it a shot. With a service_interleave_factor of
> > 's', that means that Nagios will us its smart method to schedule
> > 'initial' service checks. How it does this is pretty well
> > documented here:
> http://nagios.sourceforge.net/docs/1_0/ ... check_dela
> y
> That's how I have it set up, and I did certainly read that portion of the
> document to make sure it wasn't my User Error (TM).
> > However, if you do
> > something like have one service that checks once every 2 hours,
> > it totally blows the average and will cause Nagios to space out
> > the initial service check schedule over a much wider time then
> > it should. Do you have any checks that are being tested much
> > less frequently then the rest? That could be causing what you
> > are seeing.
> That is not only the case, but I reported in my original message that it was
> most likely the cause of the bug, as that's when I started to see the
> problem.
> > However, if you have 'retain_state_information' set to a 1 and
> > you simply add 1 new service and the same thing happens, then I
> > would say that that would be a bug, since Nagios shouldn't have
> > to schedule all of the services initial checks, only the new
> > one,
> > so it should be almost immediate.
> I do have retain_state_information set to '1', yes. Thus, all of the
> existing services are polled fine after a restart (assuming they have been
> polled at least once), it's only the initial check of new services that has
> the problem. Hence the subject. =)
> So it _is_ a bug, then. Could someone address it, please? =)
> Additionally, if the issues are separate (which they may not be, I don't
> know the internals of the program that well) could Nagios be changed to
> initially schedule services properly if the state of all of the services IS
> new?
> I'd like to add some checks to Nagios to make sure certain daily reports are
> completed properly, these would be run once a day and would compound this
> problem. I'm holding off on that for now, obviously. =)
> Thanks again for everyone's time,
> Darren Gamble
> Planner, Regional Services
> Shaw Cablesystems GP
> 630 - 3rd Avenue SW
> Calgary, Alberta, Canada
> T2P 4L4
> (403) 781-4948
> --__--__--
> Nagios-devel mailing list
> [email protected]
> End of Nagios-devel Digest
