[Nagios-devel] Problem starting Nagios 2.0b2
Hi!
What should I do to make it work?
OS is Suse 9.1
# /etc/init.d/nagios start
Starting network monitor: nagios
reset_variables() start
init_macrox_names() start
init_macrox_names() end
reset_variables() end
read_main_config_file() start
Config file: /usr/local/nagios/etc/nagios.cfg
Line 19 = 'log_file=/usr/local/nagios/var/nagios.log'
log_file set to '/usr/local/nagios/var/nagios.log'
Line 64 = 'cfg_dir=/usr/local/nagios/etc'
Line 78 = 'object_cache_file=/usr/local/nagios/var/objects.cache'
Line 91 = 'resource_file=/usr/local/nagios/etc/resource.cfg'
processing resource file
'/usr/local/nagios/etc/resource.cfg'
read_resource_file() start
processing resource file '/usr/local/nagios/etc/resource.cfg'
$USER1$ set to '/usr/local/nagios/libexec'
read_resource_file() end
Line 101 = 'status_file=/usr/local/nagios/var/status.dat'
Line 109 = 'nagios_user=daemon'
nagios_user set to 'daemon'
Line 117 = 'nagios_group=daemon'
nagios_group set to 'daemon'
Line 129 = 'check_external_commands=0'
check_external_commands set to FALSE
Line 148 = 'command_check_interval=-1'
command_check_interval set to -1
Line 160 = 'command_file=/usr/local/nagios/var/rw/nagios.cmd'
command_file set to '/usr/local/nagios/var/rw/nagios.cmd'
Line 168 = 'comment_file=/usr/local/nagios/var/comments.dat'
Line 176 = 'downtime_file=/usr/local/nagios/var/downtime.dat'
Line 184 = 'lock_file=/usr/local/nagios/var/nagios.lock'
lock_file set to '/usr/local/nagios/var/nagios.lock'
Line 194 = 'temp_file=/usr/local/nagios/var/nagios.tmp'
temp_file set to '/usr/local/nagios/var/nagios.tmp'
Line 204 = 'event_broker_options=-1'
event_broker_options set to 8191
Line 233 = 'log_rotation_method=d'
log_rotation_method set to 2
Line 241 = 'log_archive_path=/usr/local/nagios/var/archives'
log_archive_path set to '/usr/local/nagios/var/archives'
Line 249 = 'use_syslog=1'
use_syslog set to TRUE
Line 257 = 'log_notifications=1'
log_notifications set to TRUE
Line 265 = 'log_service_retries=1'
log_service_retries set to TRUE
Line 273 = 'log_host_retries=1'
log_host_retries set to TRUE
Line 282 = 'log_event_handlers=1'
log_event_handlers set to TRUE
Line 294 = 'log_initial_states=0'
log_initial_states set to FALSE
Line 305 = 'log_external_commands=1'
log_external_commands set to TRUE
Line 314 = 'log_passive_checks=1'
log_passive_checks set to TRUE
Line 346 = 'service_inter_check_delay_method=s'
service_inter_check_delay_method set to 2
Line 355 = 'max_service_check_spread=30'
max_service_check_spread set to 30
Line 371 = 'service_interleave_factor=s'
Line 387 = 'host_inter_check_delay_method=s'
host_inter_check_delay_method set to 2
Line 396 = 'max_host_check_spread=30'
max_host_check_spread set to 30
Line 408 = 'max_concurrent_checks=0'
max_parallel_service_checks set to 0
Line 416 = 'service_reaper_frequency=10'
service_check_reaper_interval set to 10
Line 429 = 'auto_reschedule_checks=0'
auto_reschedule_checks set to FALSE
Line 441 = 'auto_rescheduling_interval=30'
auto_rescheduling_interval set to 30
Line 456 = 'auto_rescheduling_window=180'
auto_rescheduling_window set to 180
Line 464 = 'sleep_time=0.25'
sleep_time set to 0.250000
Line 476 = 'service_check_timeout=60'
service_check_timeout set to 60
Line 477 = 'host_check_timeout=30'
host_check_timeout set to 30
Line 478 = 'event_handler_timeout=30'
event_handler_timeout set to 30
Line 479 = 'notification_timeout=30'
notification_timeout set to 30
Line 480 = 'ocsp_timeout=5'
ocsp_timeout set to 5
Line 481 = 'perfdata_timeout=5'
Line 495 = 'retain_state_information=1'
retain_state_information set to TRUE
Line 507 =
'state_retention_file=/usr/local/nagios/var/retention.dat'
Line 519 = 'retention_update_interval=60'
retention_update_interval set to 60
Line 530 = 'use_retained_program_state=1'
use_retained_program_state set to TRUE
Line 541 = 'use_retained_scheduling_info=0'
use_retained_scheduling_info set to FALSE
Line 551 = 'interval_length=60'
interval_length set to 60
Line 562 = 'use_aggressive_host_checking=0'
use_aggressive_host_checking set to FALSE
Line 575 = 'execute_service_checks=1'
execute_service_checks set to TRUE
Li
...[email truncated]...
